THOMAS'S WEB SITE
Cherry BX-2
Canopy Sealing
As mentioned yesterday, I glued the CR sealing in place and sealed off the front edge with a polyurethane sealer.
The contact glue from UHU (Kraftkleber flüssig) should be fine with its tasks. The tech specs give a temp. range from -15 to +70 degrees C .
The Sikaflex 221 for the CR fugue on the lower tank sealing is fine down to -40 C.
Cherry BX-2 Home
4021
Avionics/Instrument
Electrics/Instrument
176
306
Horizontal Stab.
Prebuilding Hours no
Projectinspection
Retractable Gear
97
252
Seating
Stand
Tank
60
Vertical Stabilizer
Wing Loading Test
Workshop
